My Flash Drive No Longer Works After Installation
Problem
After installing aTV Flash, the flash drive is no longer usable.
Solution
Reformat the flash drive as described below.
Mac Users
1. On a Mac navigate to Applications > Utilities > Disk Utility
2. Select the USB flash drive from the list on the left.
3. Click the 'Erase' tab in the main section of the application.
4. (Optional) Click the 'Security Options' button, and select 'Zero Out Data'.
5. Click the 'Erase' button.
Windows Users
1. Download the formatting tool located here.
2. Install the program onto your PC.
3. Run the program, and select the flash drive you wish to format. (Note: leave the 'Quick format' option unchecked)
0 Comments
Article is closed for comments.
Powered by Zendesk
