Seas0nPass
  • Updated
This is a legacy product. Some features may no longer be working, and support is no longer available.
Seas0nPass supports the 2nd gen Apple TV running version 5.3.
A tethered version of 6.2.1 can be installed by right-clicking the 'Create IPSW' button.
Older Apple TV versions can be used with saved firmware signatures.
The 3rd gen Apple TV is not supported.
For the newer 4th gen (and later) Apple TV download Infuse from the App Store!
Download Links
Seas0nPass for Mac
Seas0nPass for Windows
Video tutorial
Troubleshooting tips
Contribute
Even though Seas0nPass is provided at no cost, countless hours have gone into making it the simplest and most reliable jailbreak tool for the Apple TV. To support future development, please think about picking up a copy of aTV Flash (black) - it's really awesome!
Update: aTV Flash (black) is now available on GitHub!
Thanks! 😀
Pre-launch checklist
  1. Latest version of iTunes.
  2. Latest version of Seas0nPass (use links above).
  3. micro USB cable.
  4. Disconnect any iPods, iPhones, and iPads from your computer.
Using Seas0nPass to jailbreak the Apple TV
Step 1: Unzip the 'Seas0nPass.zip' file and launch Seas0nPass.
Step 2: Select the 'Create IPSW' button to start the jailbreak process.
Step 3: When prompted, connect your Apple TV to your Mac/PC using a micro-USB cable (leave power cable disconnected).
Once the light on the front of the Apple TV begins to flash rapidly, point the remote at the Apple TV and hold both the MENU and PLAY/PAUSE buttons for 7 seven seconds.
Note: This step will require the silver (aluminum) Apple TV remote that was included with the ATV2. The older, white (plastic) remotes will not work.
Step 4: The latest Apple TV software will be downloaded and used to create a custom 'jailbroken' software file.
Step 5: Seas0nPass will complete the restore automatically, and confirm when complete.
Note: To confirm the jailbreak was successful a (temporary) red FC logo will appear in place of the Settings icon - as shown below.
Using Seas0nPass for a 'tethered boot'
Some Apple TV software versions require a tethered boot. This means the Apple TV must be connected to a computer for a brief moment during startup.
Note 2: The Apple TV MUST be disconnected from the computer (for at least a brief moment) after restoring for the tethered boot process below to work properly.
Step 1: Open Seas0nPass and select the 'Boot Tethered' option.
Step 2: When prompted, connect the Apple TV to your computer via USB. Wait for the rapid flashing light then connect the power cable. Once both are connected hold both the 'MENU' and 'PLAY/PAUSE' buttons for 7 seven seconds.
Step 3: Seas0nPass will complete the tethered boot automatically. Once complete, remove the USB cable and connect the HDMI cable.
Note: Timing is key. Once the you receive the success message shown below, the USB cable should be removed and HDMI cable connected before the light on the front of the Apple TV stops flashing. (Don't worry there is ample to do this, so you don't need Superman speed).
Share this article
Was this article helpful?
1535 out of 1938 found this helpful
