Saving Firmware Signatures
From time to time Apple will stop 'signing' certain firmware versions which prevents these versions from being installed. The timing usually coincides with the release of an updated firmware version, but you can easily retain the ability to install these older versions by backing up your firmware signatures.
Backing up your firmware signatures will ensure you can reinstall a specific firmware version, or even downgrade to an older version, in the future.
Requirements
  1. The latest version of aTV Flash (black), Seas0nPass or TinyUmbrella.
  2. A micro USB cable.
Backup using aTV Flash (black)
Note: Backups will be done automatically when installing or updating aTV Flash (black). They can also be triggered manually by following the steps below.
Step 1: With aTV Flash (black) installed, navigate to the Maintenance --> Settings --> Manage Backups menu.
Step 2: Select the 'Backup My Firmware' option.
Step 3: Firmware signatures will be saved, and a list of previously saved signatures will appear below. (Note: firmware signatures are also saved automatically when installing or updating the Maintenance item)
Backup using Seas0nPass
Step 1: Download the beta version of Seas0nPass here.
Step 2: Connect the Apple TV via USB
Step 3: Launch Seas0nPass.
Step 4: Right-click the 'Create IPSW' button and select the 'Save firmware signatures...' option.
Step 5: Follow the prompts provided by Seas0nPass.
Backup using TinyUmbrella
Step 1: Power on your Apple TV and connect it to your computer using a micro USB cable.
Step 2: Open TinyUmbrella.
Step 3: Select your Apple TV from the lefthand column and select the 'Save SHSH' button.
Step 4: Once the SHSH signatures have been saved, a new entry will be listed in the center content area. From here on out you will be able to restore your Apple TV using any of the SW versions listed here.
Using saved signatures to install an older version
Step 1: Connect Apple TV via USB
Step 2: Launch Seas0nPass
Step 2: Right-click the 'Create IPSW' button and select your desired version.
Step 2: Seas0nPass will handle fetching saved signatures and restoring the firmware automatically.
0 Comments
Article is closed for comments.
Powered by Zendesk
