Connection Info for Emby, Jellyfin, and Plex
  • Updated
Infuse is able to connect to Emby, Jellyfin, and Plex servers, and provides various headers which include details about the connection type, such as User-Agent, Product, and Version. Server admins can use this header info to route and control requests that come from Infuse.
Connection Types
Infuse will use one of three connection types when making requests.
Infuse-Direct
This allows Infuse to access the server directly, and load content on-demand as needed. This is similar to how native apps interact with the server. There is no pre-caching of data or full scanning of libraries required. This is the default connection type in Infuse 7.7+.
Infuse-Library
This is the original connection method used in Infuse, and will pre-cache data from the server within the Infuse app. This is an optional connection type in Infuse 7.7+.
Infuse-Download
This connection type will be used when downloading files from the server for offline use.
In versions prior to 7.7, a connection type of ‘Infuse’ was used for all requests.
Example Requests
Emby/Jellyfin
GET Request HTTP/1.1
Host: IP:port
X-Emby-Authorization: MediaBrowser Token="#####", Client="Infuse-Direct", Version="7.7", Device="####", DeviceId="###-#-###"
Accept: application/json
User-Agent: Infuse-Direct/7.7
Accept-Language: en-US,en-GB;q=0.9,en;q=0.8
Accept-Encoding: gzip, deflate
Connection: keep-alive
Plex
Host: IP:port
X-Plex-Device: ####
X-Plex-Container-Start: 0
X-Plex-Platform: ###
X-Plex-Product: Infuse-Direct
X-Plex-Client-Identifier: ####-#-###
X-Plex-Container-Size: 2000
X-Plex-Device-Name: ###
X-Plex-Version: 7.7
X-Plex-Token: ##########
Share this article
Was this article helpful?
6 out of 23 found this helpful
