Use Overflow to combine multiple menus into a single menu.
Install
Navigate to the Maintenance --> Manage Plugins menu and select the Overflow item. Restart the AppleTV when prompted.
Note: If 'Overflow' already appears in the main menu this step is not required.
Features
Setup
Each item can be set to one of the following.
- A gray gem means the item is ignored by Overflow and will appear in the main menu.
- A red gem means the item is hidden from both Overflow and main menu.
- A green gem means the item is hidden from the main menu but will appear in the Overflow menu
After making your selections, select the Restart Finder option.
Usage
After the restart the selected items will appear under the Overflow menu.
Selecting the item from the Overflow menu will show the normal features for the selected item.
