Installing Extras
  • Updated
After installing aTV Flash (black) from a Mac or PC 'extras' can be installed, updated and removed through the Maintenance --> Manage Extras menu.
Installing Extras
Extra features can be installed through the Maintenance menu.
  1. Navigate to the Maintenance --> Manage Extras menu.
  2. Highlight the item you wish to install, and press the center (select) button to install it.
  3. Once the install is complete you will be prompted to relaunch the Apple TV.
Updating Extras
Updates are easily installed through the Maintenance menu.
  2. Items that have an update available will have the word 'Update' next to them.
  3. Highlight the item, and press the center (select) button to download and install the latest version.
  4. Once the update is complete you will be prompted to relaunch the Apple TV.
Removing Extras
Removing unwanted features can be easily done through the Maintenance menu.
  2. Highlight the item to be removed, and press the right arrow (>>) button to remove it.
  3. You will be prompted to confirm the removal and relaunch the Apple TV.
Share this article
Was this article helpful?
117 out of 144 found this helpful
