API for Third-Party Apps & Services
  • Updated
Developers of third-party apps and services can leverage Infuse’s powerful video playback features to play, bookmark, and download videos using flexible URL schemes. Support for x-callback is also available which allows for returning back to another app once an action has been completed.
Available platforms: iPhone, iPad, Apple TV, Mac, and Vision
Sending Videos to Infuse for Playback
Play one or more videos and return to another app when finished
infuse://x-callback-url/play?url=https://files.firecore.com/infuse/sample-5s-360p.mp4&
filename=Inception-2010.mp4&
sub=https://files.firecore.com/infuse/example.srt&
url=https://files.firecore.com/infuse/mov_bbb.mp4&
filename=Mad-Men-S01-E01.mp4&
sub=https://files.firecore.com/infuse/example2.srt&
x-success=some-app://success&
x-error=some-app://error
Success and error reporting
x-success
some-app://success?lastPlayedUrl=https://files.firecore.com/infuse/sample-5s-360p.mp4&
progress=0.33
x-error
some-app://error?errorCode=100&
errorMessage=Unsupported%20content&
failedUrl=invalid_url1&
failedUrl=invalid_url2
Notes
  • Supports single or multiple url entries
  • Subtitle and filename parameters are optional
  • Specifying a filename can help provide accurate metadata when using one of the recommended file naming styles
  • All URLs are played sequentially as a temporary playlist
  • x-success is not called for each individual URL in the list, but once when playlist playback ends or when the player is closed (returns last URL + progress 0–1).
  • x-error is called once and returns failed URLs (invalid or playback errors)
Saving Links in Infuse for Playback and/or Download
Save (bookmark) one or more video URL to play later
infuse://x-callback-url/save?
sub=https://files.firecore.com/infuse/example1.srt&
download=0&
x-success
some-app://success
x-error
Notes
  • Download parameter can be used to begin downloading files for offline playback (0=save link only, 1=save link and download)
  • Download parameter applies to the entire request
  • x-success has no parameters
  • x-error is called once and returns failed URLs (EG invalid links)
URL Encoding
Per the x-callback-url spec, all querystring values should be url-safe or encoded. Unencoded URLs may work in some cases, but when using actions with multiple parameters or URLs with multiple keys you will probably need to manually encode your URLs.
Examples
Unencoded URL
http://192.168.162.100/Movies/movie.mkv
Encoded URL
http%3A%2F%2F192.168.162.100%2FMovies%2Fmovie.mkv
Deep Linking to Infuse Library Items
Apps can link directly to items in the Infuse library using the appropriate TMDB ID numbers. Note: If a title is not present in the library, a placeholder page with TMDB data will be shown.
Link to a movie
infuse://movie/{tmdb_id}
Link to a TV series
infuse://series/{tmdb_id}
Link to a TV series season
infuse://series/{tmdb_id}-{season_number}
Link to a TV series episode
infuse://series/{tmdb_id}-{season_number}-{episode_number}
Share this article
Was this article helpful?
80 out of 126 found this helpful
