Unable to See or Connect to Network Devices
  • Updated
Apple has introduced an extra permission option on iPhone, iPad, and Mac that allows you control which apps are able to access devices on your local network.
This setting will need to remain enabled so Infuse is able to connect to your devices.
How to Enable Local Network Access
  1. Open System Settings and locate the 'Privacy & Security' option (near the bottom of the list).
  2. Navigate to the 'Local Network' section.
  3. Check to ensure the switch next to Infuse is toggled ON
Share this article
Was this article helpful?
13 out of 93 found this helpful
