Library Scanning & Indexing
  • Updated
Infuse features a set of powerful scanning and indexing features that work together to present files in an organized and visually pleasing manner. An array of settings are available to fine-tune how this works.
These setting do not apply to Emby, Jellyfin, or Plex connections.
Metadata Fetching
By default, Infuse will work to match videos in your library to movie and TV show titles found on The Movie Database (TMDB). Information including title, description, cast information, poster artwork, landscape (fanart) artwork, and database IDs (for integration with other services such as Trakt and OpenSubtitles) will be downloaded automatically.
To get the most accurate matches it is best to use one of the recommended file naming styles.
If the rare event the correct title is not found automatically the Edit Metadata option can be used to search for the correct match manually.
Avoid Matching Certain Files or Folders
If there are certain videos (such as home movies, tutorials, sample videos, etc...) that Infuse should not match to titles found on TMDB, these can be excluded from the scanning process. This can be set globally for all files, for a specific folder, or for individual files. More information on the options can be found here.
Infuse does not collect or share any personal or identifying information about your library or files as part of the matching process.
Embedded Artwork
If you want Infuse to make uses of artwork contained within your video files the ’Prefer Embedded Artwork’ option found in Infuse > Settings > General can be enabled.
Having both the ‘Metadata Fetching’ and ‘Prefer Embedded Artwork’ options enabled at the same time will allow Infuse to use any embedded artwork it finds and then use artwork from TMDB to fill in any missing gaps.
Other Library Scanning Options
For each file source (share) a number of options are available which can be adjusted to customize how Infuse scans the files located there. These options can impact the speed of scanning and browsing and also affect how files and folders are presented in Infuse.
These options can be found under the ‘Advanced’ tab when editing details for a saved network share.
Pre-Cache Details
This setting will determine whether or not Infuse performs a deep scan of Library files as part of the indexing process. The deep scan process will fetch and store details such as runtime, codec info, and other file specs for videos in the Library.
When enabled: Infuse will work to fetch details for all videos so they are ready and waiting. This will require longer library indexing times.
When disabled: Infuse will fetch these detail on-demand while browsing. This will allow for shorter library indexing times.
Due to API request limitations this is disabled by default for all cloud services (Dropbox, Google Drive, Aliyun Drive, etc...).
Pre-Cache Artwork
This setting will determine whether Infuse downloads poster and fanart images as part of the indexing process.
When enabled: Infuse will work to fetch artwork for all videos so they are ready and waiting. This will require longer library indexing times and use more on-device storage.
When disabled: Infuse will fetch artwork on-demand while browsing. This will allow for shorter library indexing times and use less on-device storage.
Smart Folders
‘Smart Folders’ is a feature which allows a folder to be ‘flattened’ and displayed as a playable item instead of a regular folder. This can be useful if movies are organized into individual folders with video, artwork, metadata, and subtitles files inside. However, it can lead to longer load times when opening larger folders.
Learn more about Smart Folders
Auto Scan
This setting will determine whether Infuse automatically scans the share when the app is opened (and periodically when the app is left open and idle).
When enabled: Infuse will automatically scan the connected share to ensure the library is up-to-date to reflect new, changed, and removed files.
When disabled: Infuse will not automatically scan the connected share. A manual scan can be triggered at anytime by tapping the Refresh icon on the home screen, or the scan option found in Infuse > Settings > Library.
Recommended Settings
Individual preferences can vary depending on the situation, but below is an overview of the recommended settings based on specific goals.
I browse directly via folders and want to have the fastest possible browsing experience
  • Metadata Fetching = ON
  • Prefer Embedded Artwork = OFF
  • Smart Folders = OFF
  • Pre-Cache Details = ON or OFF
  • Pre-Cache Artwork = ON
  • Auto Scan = ON or OFF
I browse via the Library and want to have the shortest possible indexing times
  • Smart Folders = (does not apply)
  • Pre-Cache Details = OFF
  • Pre-Cache Artwork = OFF
I browse via folders or the Library and want to complete scanning all at once
  • Auto Scan = ON
I want to limit the storage space used on my device
Related Guides
Setting Up Your Library
Overriding Artwork and Metadata
Share this article
Was this article helpful?
9 out of 17 found this helpful
