Installing and Updating Infuse
  • Updated
Details on installing Infuse for the first time, as well as manually updating to a new version can be found below.
Installing Infuse
To download Infuse on your device you can use this direct link or simply search for ‘Infuse’ on the App Store.
Updating Infuse
Updates are usually installed automatically by Apple on a periodic basis, but if you want to update to new version manually you can follow these steps.
Details on the features and improvements included in each update can be found here.
On iOS/visionOS
  1. Open the App Store app
  2. Tap your profile icon in the top right corner
  3. Drag down on the list of apps to refresh the list
  4. Tap the ‘Update‘ button next to Infuse
On Apple TV
  2. Search for ‘Infuse’
  3. Open the details page for ‘Infuse’
  4. Tap the ‘Update‘ button which appears on the page
On Mac
  2. Click the ‘Updates‘ tab in the left sidebar
  3. Select ‘Reload Page‘ from the ‘Store’ menu in the top nav bar
  4. Click the ‘Update‘ button next to Infuse
If the latest version does not appear you may try restarting your device. This can sometimes help to get updates to appear quicker.
Share this article
Was this article helpful?
19 out of 42 found this helpful
