STRMLNK Files
  • Updated
A STRMLNK file is a versatile format which can be used to build a library of lightweight text files, each containing an HTTP link to a video title on an external service (such as Netflix, Apple TV+, YouTube, etc...). Adding these files to the Infuse library will allow browsing of both owned and streamed videos in a single place.
External videos will appear with an 'Open' button and clicking this will direct to you the specific 3rd party app for playback.
Usage
Create a normal text file and rename the .txt extension to .strmlnk. Then using a text editor application (like TextEdit on Mac or Notepad on Windows) enter the the direct URL link of the video file.
Examples
File name
Total-Recall-1990.strmlnk
File contents
https://tv.apple.com/movie/total-recall/umc.cmc.25btbyzkrdyo50inh72zp90cl
The naming style of the .strmlnk file should follow the recommended naming styles to ensure the appropriate movie or TV show details can be fetched from TMDB.
Share this article
Was this article helpful?
18 out of 22 found this helpful
