Streaming from iCloud Drive
  • Updated
Infuse is able to connect to iCloud Drive to browse, stream, and download files.
Add iCloud Drive (iOS)
Step 1. Navigate to the Add Files menu in Infuse, and click the ‘Add...’ option and then locate the ‘Add Local Folder’ option.
Step 2. Using the Files app UI browse for the iCloud Drive folder (or sub folder) you would like to add. Then navigate inside the folder and select the ‘Open’ option.
Step 3. Adjust how the name appears in Infuse (if desired).
Step 4. Access the added folder in the Infuse Files or Library sections.
Access iCloud Drive Files on Apple TV
While Apple does not currently provide a direct option for browsing files stored in iCloud Drive on Apple TV, in Infuse it's possible to use a separate device (EG iPhone) for browsing and to bookmark links to individual files which can then be played on Apple TV.
Step 1. Open Infuse and browse the iCloud Drive connection in the Files or Library sections.
Step 2. Locate the file to be played on Apple TV. Long-press it and select the ‘Add to Links’ option.
Step 3. A direct link to the video will added to the ‘Links‘ section in Infuse which can then be accessed on Apple TV.
Items added to the Links section will be included in the Infuse library by default. This can be disabled by deselecting the Links item in the Infuse > Settings > Library menu.
Generated links for iCloud Drive files are valid for 30 days. After this time the link would need to be re-added in order for the file to be played.
Share this article
Was this article helpful?
35 out of 73 found this helpful
