Fixing Mismatched Titles
  • Updated
If Infuse is unable to find the correct match for a movie or TV show automatically, it is possible to select a title manually using search.
Making Manual Corrections
Step 1: Open the details page for the incorrectly matched item.
Step 2: Select the Edit Metadata option from the 3 dots menu in the upper right corner (on Apple TV this is displayed near Play button).
Step 3: Select the correct title from the list of matches (use the Search box if no suitable matches are found).
When correcting an entry for a TV show, only a single episode file will need to be changed. All episodes in the series will then be matched automatically.
Share this article
Was this article helpful?
34 out of 112 found this helpful
