Using Embedded Metadata
  • Updated
For some videos (like home movies) you may not want Infuse to try to fetch metadata and artwork for your videos. In this case, you can direct Infuse to use embedded metadata and artwork for a single video, a single folder, or for all videos.
For a Single Video
Step 1: Long-press (right-click on macOS) on the video's poster and select the ‘Edit Metadata’ option.
Step 2: Select the ‘None - use embedded metadata’ option which appears at the top of the list.
For an Entire Folder
To use embedded metadata for an entire folder (including any subfolders) long-press (right-click on macOS) on the folder icon and tap the ‘Metadata’ option to change it from ‘Online’ to ‘Local’.
Folders tagged as local metadata can be untagged, but the cached info will remain until a title is edited manually or the clear all metadata option in Settings > General is used.
For All Videos
To disable metadata fetching for all videos (and rely on embedded metadata/artwork only) disable the ‘Metadata Fetching’ option found in Infuse > Settings > Metadata & Artwork.
Share this article
Was this article helpful?
25 out of 64 found this helpful
