Overriding Artwork and Metadata
  • Updated
In some cases it may be useful to add your own metadata and artwork for specific titles. This may be the case when you want to see a specific image, or add details for things like home videos.
To override artwork and/or metadata for movies and TV shows using local files be sure to enable the relevant option(s) found in Infuse > Settings > Metadata & Artwork.
Favorite & Folder Artwork
Custom artwork can be set for favorites and folders by adding local image files to the favorite/folder and following the naming guidelines below.
Favorites
Custom artwork can be set for favorites by adding an image inside the favorite.
The official Infuse images as well as user-submitted images can be found here.
Apple TV
  • favorite-atv.jpg (or png) - 614 x 346px recommended size
On Apple TV, favorite artwork can also be selected by long-pressing on a favorite icon and choosing the 'Select Favorite Artwork' option.
iOS/Mac
  • favorite.jpg (or png) - 500 x 750px recommended size
Folders
Custom artwork can be set for folders by adding an image inside a folder.
  • folder.jpg (or png) - 500 x 750px recommended size
Movie Artwork
Enable the ‘Prefer Local Artwork’ option in Infuse > Settings > Metadata & Artwork to ensure the local artwork images are used.
Poster
Appears on home screen and in grid and list views
To override, place an image with the same name alongside the video file.
Inception-2010.mkv
Fanart
Appears on details page and Up Next list.
To override, place an image with the same name + 'fanart' text alongside the video file.
Inception-2010.mkv
Logo
Appears on details page.
To override, place an image with the same name + 'logo' text alongside the video file.
Inception-2010.mkv
TV Show Artwork
Overriding series/season artwork is available when episodes are organized into folders by season (Series Name/Season X/episodes.mkv).
E.G. Breaking Bad/Season 1/Breaking Bad S01E01.mkv
Usage details
Episode image
seriesname/season 1/episodefilename.jpg
Season poster
seriesname/season 1-poster.jpg
All Seasons poster
seriesname/season-all-poster.jpg
Series poster (available only while using Library)
seriesname/poster.jpg
Series fanart
seriesname/fanart.jpg
Series logo
seriesname/logo.png (or clearlogo.png)
Overriding series/season artwork is not possible when using some streaming connections, including: Google Drive, OneDrive, Box, pCloud, Aliyun Drive, Baidu NetDisk, 115 Cloud Drive, and 123 Cloud Drive.
Recommended poster size 1000 x 1500px, (1:1.5 ratio). Recommend landscape image size is 1920 x 1080px or 3840 x 2160px (16:9 ratio).
Movie Metadata
Textual metadata can also be added manually through the use of XML or NFO files. These files can be created using software like tinyMediaManager and the most common tags will be supported in Infuse.
Usage
To override for a movie, place an XML/NFO file with the same name alongside the video file.
Inception-2010.mkv
Inception-2010.nfo
Samples
TV Show Metadata
Using local metadata to manually organize and group TV episodes is not supported at this time, but may be added in a future update. For now, it is recommended to keep the ‘Metadata Fetching’ option (found in Infuse > Settings > General) enabled and use one of the recommended TV show file naming styles. This will allow these items to be matched and grouped using information from TMDB.
Overriding metadata and artwork is not available when connecting via UPnP or DLNA.
Share this article
Was this article helpful?
63 out of 153 found this helpful
