Excluding Files and Folders
  • Updated
In some cases, there may be folders of items which you may not want included in Infuse's library.
Usage
If you have folders you don't want included in the library, there are a few options available which will prevent Infuse from indexing these.
  1. Add a hidden '.nomedia' file. If present in a folder, Infuse would not index any items in that folder.
  2. Add a folder as a Favorite and then deselect it in Infuse > Settings > Library.
  3. If these folders happen to contain things like home videos, you can tag these folders to use local (embedded) metadata.
Share this article
Was this article helpful?
32 out of 107 found this helpful
